Zener Shunt Regulator Current
Discussion in 'General Electronics Chat' started by tracecom, Aug 26, 2012.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,880
    1,396
    In the circuit below, assume that ZD1 is a 1N4733A, 5.1V, 1W, zener. What should the value of R_z be if R_load could be disconnected during operation? Am I correct that R_z should be sized to limit the total power to .5 watts, which means that the maximum current should be 72mA, and R_z should be 96 Ω and 1 watt?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Zener diodes kind of creep up to their rated voltage as the curent increases. I have found that running them at half their wattage limit works well.
    P=IE
    1/2W = 5.1V x I
    I=98 ma
    12-5.1 = 6.9V
    R=E/I
    R=6.9/.098
    R=70 ohms
    P=E^2/R
    P= 6.9^2/70
    P= .68 watts actual
    size the resistor at more than .68 watts
    absf and tracecom like this.
  3. tracecom
    Apr 16, 2010
    3,880
    1,396
    #12,
    While waiting for a reply, I redid my calculations and came up with the same numbers you did! :D Thanks. I understand it (for the moment, at least.)
    That's the part that was left out of the textbook.
    absf likes this.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Note that the 1N4733A's test current is 49mA - half the max current.
  5. tracecom
    Apr 16, 2010
    3,880
    1,396
    Thanks,
    I hadn't looked at the datasheet, but I should have. I now see the test current, but I don't see the max current. Why wouldn't the max current be 1 W / 5.1 V = 196 mA?
    absf likes this.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Oops, I thought it was a half watt zener.:(
    I guess I should pay attention.
