zener resistor
Discussion in 'General Electronics Chat' started by Gytis111, Apr 2, 2013.
  1. Gytis111
    Dec 24, 2012
    10
    it's the first time i write here.
    I'm trying some simple circuits and one of them is not working the way i think it should.
    Dc source is about 8V and zener is 3,36V. The problem is that zeners voltage seems to depend on the resistor value. If i take small value, like 200ohm, zener takes 3,6V which is good. If i take resistor of 20kohm, i get only 2,25V on zener and don't understand why, because i thought that resistor only consumes extra voltage which is left from zener.:mad:
    Could somebody explain why? I added the scheme
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  3. Gytis111
    Dec 24, 2012
    10
    Hi bertus,
    i was actually using the scheme from that page. I'm missing something obvious or understanding some fundamentals wrong. Why does voltage depends on load, i mean load voltage is the same as zener voltage(they are parallel)?
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    The current through the series resistor will split into the zener diode and the load.
    The zener will need a certain amount of current to regulate the voltage.
    When the load is taking to much current, the voltage will drop.
    Bertus
    Gytis111 likes this.
  5. Gytis111
    Dec 24, 2012
    10
    I see, i thought that a certain amount of voltage is enough no matter how much current is passing. So, if something(big value resistor) is slowing down the current too much, zener will not get saturated even if there is enough of voltage. Will it be in some sort of semi-awake situation?
  6. k7elp60
    Nov 4, 2008
    478
    69
    I think there are some zener diode charastics that you need to realize. One is the Izk(or the minimum zener current to sustain zener breakdown) In your circuit you were using a 20K resistor in series this equates to 8-3.6=4.4V/20K or 220 uA. This may be too small for the zener to regulage. Not knowing if the zener is 1/2W or 1W and if it is a suffex A that means 5% of the nominal value.
    Consider the resistor in series with th zener and the load in parallel. If the load current increases the zener current will decrease and versa visa.
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    Look up the data sheet for your zener. It should show the dynamic curve for voltage vs current. As you will see, it is non-linear and even more so at low current levels.
  8. #12
    Nov 30, 2010
    16,663
    7,310
    It's always safe to run a zener at half its rated wattage. That pretty much tells you the maximum current you can allow for the load. As with many things electronic, you start at the end (the load) and calculate backwards to get to the resistor.
