Change the PNP to NPN must be care about duty cycle to match what he want.Please consider the following for switching an relay:
Of course. They are worried about lack of voltage for the relay, but there would be none since the transistor is SINKING current straight to ground.Change the PNP to NPN must be care about duty cycle to match what he want.
Omron G5V-1 relays are available with coils rated for 3V, 5V, 6V, 9V, 12V and 24V. I think we can assume he's using the right one...Yes well I must have missed something then. Operating a 5 volt relay off 3V3? Well the whole schema seems wrong then.
Huh???? Any transistor in series with the relay, whether it's an NPN or a PNP, is going to have a Vce(sat), and it's going to subtract from the net voltage available to the relay coil. That loss may or may not be significant, and in this case it might not be judging from the relay pull-in specs, but it's still there. What makes you think that just because the transistor is sinking current rather than sourcing it, there would be no Vce(sat) loss at all????Of course. They are worried about lack of voltage for the relay, but there would be none since the transistor is SINKING current straight to ground.
Yeah I guess you will get your obvious drop of ~0.65 volts between base and emitter. But this is ridiculous to think that such and entity cannot be done with just an 2-cent common garden variety BJT.Huh???? Any transistor in series with the relay, whether it's an NPN or a PNP, is going to have a Vce(sat), and it's going to subtract from the net voltage available to the relay coil. That loss may or may not be significant, and in this case it might not be judging from the relay pull-in specs, but it's still there. What makes you think that just because the transistor is sinking current rather than sourcing it, there would be no Vce(sat) loss at all????
Because I believe I had my logic reversed from what I intended in the first place, and I think this reversal fixes it. The goal is to energize the relay coil for short, equal length bursts of time and to leave it off for longer, variable lengths of time (set by pot.) I copied some formulas wrong when I first worked out 555 timer calcs and had duty cycle reversed, among other issues. I think (hope) the current p-channel arrangement provides the duty cycle I want...Why have you switched from an N-channel MOSFET in the original circuit to a P-channel MOSFET?
The results will be reversed.
Are you going to breadboard this gadget first?
I always do, simply because it brings good luck: almost every time I've tested a design before committing to PC board or sending it to a client, the thing turns out to work exactly as expected; and the few times I've skipped that step (mostly because I thought the design was too simple to bother breadboarding it), most often something doesn't work right and I end up red-faced.
Call me superstitious if you will, but that's the way it's been for me.
You guys are both absolutely right! I must confess I was considering not breadboarding this project, because money's tight, I'm developing it for free, and I don't specifically need my own version of this circuit for anything yet...It is not being superstitious. It is practicing due diligence.
Wouldn't it be the collector emitter saturation voltage that would be the issue here? That's what will be missing from the relay coil, not anything to do with the base.Yeah I guess you will get your obvious drop of ~0.65 volts between base and emitter. But this is ridiculous to think that such and entity cannot be done with just an 2-cent common garden variety BJT.
A transistor is like two diodes back to back. So yes drop between emitter and collector as well.Wouldn't it be the collector emitter saturation voltage that would be the issue here? That's what will be missing from the relay coil, not anything to do with the base.
Exactly. Vbe(sat) is irrelevant here.Wouldn't it be the collector emitter saturation voltage that would be the issue here? That's what will be missing from the relay coil, not anything to do with the base.
A wise choice. I think the design you presented in post #47 is fine just the way it is. Go for it.Regardless, this project will be a one-off, maybe at most 2 or 3 units, so a little extra expense to ensure success is probably a worthwhile investment.
Know what's worse? Sending a flawed design to someone who has more diagnostic/troubleshooting ability. Been there, done that. Really embarrassing...Plus, it'd be really rotten to send a flawed circuit plan to someone thousands of miles away who has less diagnostic/troubleshooting ability than I do.
Only if you have tickets on yourself it would be. An expert makes an slip up?Really embarrassing...
Please do not used your "personal emotional word" to insult other members and just focus on your professional viewpoint.Yeah I guess you will get your obvious drop of ~0.65 volts between base and emitter. But this is ridiculous to think that such and entity cannot be done with just an 2-cent common garden variety BJT.
I don't think so. For TO-92 packages, I'll just do a quick back-of-the-envelope calculation of maximum power dissipation and if it's less than 250 mW I don't worry about it any further. If it's more I'll take a more detailed look, considering thermal resistance, maximum junction temperature, and so on.Is there any general rule for how much heat a TO-92 package can dissipate?
I'd say yes. I reckon there's usually three distinct temperature limits: first, there's the Absolute Maximum junction temperature, above which a device can suffer catastrophic failure during a fault condition (or by careless design). Below that, there is usually an operational maximum junction temperature, above which the device might not meet all (or any) of its published specs, or even cease operating altogether until the temperature drops again. And finally, below that, there is what I would call a "performance" maximum temperature that I have to stay below to get the device performance I'm looking for. One example might be a voltage reference IC that provides the voltage reference for an extremely high performance analog-to-digital converter. I want that voltage reference to be as stable as I can make it, so I will take care not to draw any more current from it than is absolutely necessary. That way, the part will experience minimum temperature rise.Or does that depend too much on the internal workings of the component?
Sometimes that's necessary, sometimes not (see above).Do you have to calculate it based on the thermal resistance specs?
Yup. That's electronics for ya!So much to learn!
by Jake Hertz
by Duane Benson
