Zener questions
Discussion in 'General Electronics Chat' started by YorksireDave, Dec 9, 2010.
  1. YorksireDave
    Dec 9, 2010
    5
    I've come across some 30v zeners in my shed (don't ask!). I need some 6.8v and wondered if I could use the ones Ihave in any way? I was thinking could they be used in series/parallel or anything or do those rules not apply to diodes? :confused:
    Also, I've come across some IN5148 diodes which through Googling I believe are Varactor diodes! Can someone enlighten as to what they are and what I might be able to use them for. :confused:
    Thanks ;)
  2. KMoffett
    Dec 19, 2007
    2,584
    234
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  4. tyblu
    Member
    Nov 29, 2010
    199
    16
    You would have to put a 30V-6.8V=23.2V potential across the zener; this can be done by either creating a negative voltage source (-23.2V) or by floating your system ground 23.3V above a reference, then using the reference directly for the zener.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    A varactor is a diode whose capacitance varies with voltage when it is back biased. It is a variable capacitor in other words, popular with autotune features in radios (among other things).
  6. YorksireDave
    Dec 9, 2010
    5
    Many thanks people. As I have a 1000 of the diodes are they worth anything?
  7. tyblu
    Member
    Nov 29, 2010
    199
    16
    Not really worth anything. Do you know what power rating they are? DigiKey marks them up to 50c/ea for singles to ~2c/ea for 10k; 'suppose you could make $10.
