zener questions/current flow
Discussion in 'General Electronics Chat' started by jimmiegin, Apr 4, 2014.
  1. jimmiegin
    Apr 4, 2014
    49
    Hello all.
    My name is jimmy and I like Hendrix gin, hence the username jimmiegin. Now, when I am not drinking gin, and sometimes when I am, I am learning all I can about my new hobby. So my question is a basic one but is confusing me all the same. I am currently learning about transistors and zener referenced regulated power supply. What I am not sure of is current flow direction and how a resistor in series with a zener, but not with output, can limit current to the load? or have I got something totally wrong?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    Your diagram is correct. The Zener is being used as a Shunt Regulator. Current through the resistor will cause a voltage drop which will reduce the output voltage by that amount. The Zener diode starts conducting in the reverse bias direction at a value determined by the manufacturer. If the external load does not draw enough current (which is shouldn't) to cause sufficient voltage drop through the resistor, the current through the Zener makes up the difference. If you look at the data sheet for a Zener, you will see the current/voltage curve for the device which may help explain how it works
  4. Veracohr
    Jan 3, 2011
    559
    77
    The resistor will create an overall current limit. Say you have a 10V source and a 1kΩ resistor, there can't be more than 10mA total in the circuit. The zener requires a certain amount of current to attain its rated voltage, so that means there's a limited amount of current (less than the 10mA total), that is available for the load (with the zener voltage remaining constant). If the load attempts to draw too much current away from the zener, the zener voltage will drop, which will in turn reduce the current to the load.
  5. studiot
    Nov 9, 2007
    5,005
    515
  6. jimmiegin
    Apr 4, 2014
    49
    WoW thank you very much all.
