Zener pin proection
Discussion in 'The Projects Forum' started by stoopkid, Jun 30, 2012.
  1. stoopkid
    Mar 3, 2011
    136
    I plan on using a voltage divider to read 12v input with my 5v microcontroller. I was going to use a 5.1v zener to protect the pins, but I was wondering if the voltage did go over 5.1, what would the pin read? Would it still be pulled high, or would the zener pull it low?
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    Your input will read high.
    You do not need a 5.1V zener. You can clamp the input by putting a Schottky diode between the input and the +5V supply (anode at the input, cathode at the +5V supply).
