OP, note that TubeGuy said, "Allowable", not "possible". Allowable means " the maximum cuerent that the designer should allow" and he/she should pick the right resistance to prevent higher currents from ever flowing through the Zener.The maximum allowable current in amps = zener wattage/zener voltage.
For a 1 watt 12 volt zener the max current = 1w/12v ~ .083 amps.
Some zener datasheets quote the "dynamic resistance" - AFAIK; you treat the zener voltage as an absolute voltage (theoretical ideal zener) the dynamic resistance determines the VI curve after subtracting Vz.What happens one the breakdown voltage has been reached does the current conducted through a zener diode? I was thinking current increases drastically
