zener diode
Discussion in 'General Electronics Chat' started by shivashankari.c14, Apr 19, 2010.
  1. shivashankari.c14
    Apr 6, 2010
    10
    hi explain me the operation of zener diode? also wat s the difference between lzener and norma; diode?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    Zener diodes have a break down voltages, at different levels, like ,
    3.3V, 4.7V, 6.8V and so on.
    Zener operates in reverse bias where the zener voltage is the voltage dropped acroos the diode and is stable for a given zener current flowing via the diode.
    While normal diodes have no break down but a PIV, , like 50V, to thousands of volts.
    Which states that if that diode is used in a circuit whose operating voltages goes beyond it's PIV, then this diode will be destroyed.
    Normal diodes are used in forward bias and also used in reverse bias as a protection diode where voltage reversal could a problem.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
