zener diode rating
Discussion in 'General Electronics Chat' started by zahid0001000, Aug 25, 2006.
  1. zahid0001000
    Aug 25, 2006
    i have a zener diode but i dont know about its colour coding and voltage rating. plaese guide me about this
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Do you know the part number?
    Dave
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    For an experimental determination, place a resistor in series with the zener. It is most convient to have the resistor attach to the cathode. Using a variable voltage supply, place a voltage across the resistor and diode, positive with reference to the cathode. Monitor with a meter across the diode. Increase the voltage at the supply until the voltage reading between the diode's cathode and ground does not change. That will be the zener voltage. Use a resistor large enough in value so the current is in the single milliamps.
