For the following circuit:
http://i1127.photobucket.com/albums/l637/hrstar24/th_circuit1.jpg
I need to find R1 so that Iz minimum is 5 mA under worst case load, power supply, and component tolerance. Vcc varies +- 10%, β for Q1 is typically 100, but has a min of 40 and a max of 300. VBE is .7 V, and for the zener diode rz = 6Ω, it has a 6.8 voltage drop at a test current of 5 mA. I already got Vzo also. I don't really know where to start.
So in worst case load, power, and tolerance, does that just mean Vcc = 10.8 V, β = 40, and IL is 0? Can I just ignore the BJT in this case? Also the next question asks me to find Iz maximum under worst case conditions, whats the difference between Iz min and Iz max?
