I am developing a system to test a power supply with outputs of +5, +12, -12, and +24 voltage outputs. If the assembly of the power supply is correct (as in the voltages are correct at certain test points I have chosen), the LEDs will light. On the other hand, if the incorrect voltage is supplied, my tester should not light the LED.
Would Zener diodes be the best bet if I hook up the LED in series with a Zener diode and a resistor? For example, if the voltage I'm testing is supposed to be +12 V, and instead it's less than that, the LED shouldn't light due to the Zener. Also, is there any way to indicate if the voltage is greater than +12 V using the same system? (besides the intensity of the LED)
Thanks in advance.
Thanks in advance.
