Zener diode in LTSpice?
Discussion in 'The Projects Forum' started by raisintoe, Mar 17, 2016.
  1. raisintoe
    Mar 24, 2012
    46
    How do I use the zener diode in LTSpice? I am not allowed to set the breakdown voltage or anything in the zener diode's properties.
  2. ronv
    Nov 12, 2008
    3,404
    1,501
    When you select the regular diode symbol at the top of LTSpice you can then right click it and select from some installed zener diode models. If one of these is nor close enough to what you want you will need to find your model one line.
    Two good sources are yahoo users group for ltspice or ltwiki.
  3. raisintoe
    Mar 24, 2012
    46
    Thank you! All I could ever find was the blank zener diode. I got it now.
