zener diode identification help.
Discussion in 'General Electronics Chat' started by Qsilverrdc, Aug 3, 2014.
  1. Qsilverrdc
    Aug 3, 2014
    34
    Hi. Thanks for helping.
    I have a round 2 wire device I need to identify.
    Its about 1/4 inch 7mm dia.
    It is marked..
    TNR
    241
    7c22
    I can not find on web.
    Rich
  2. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    It appears to be MOV not a zener?
    Is there a problem that you need to identify it?
    Max.
  3. k7elp60
    Nov 4, 2008
    481
    69
    I agree with MaxHeadRoom. The device looks like it has a crack in the case.
    They are designed to absorb a voltage spike, that's what looks like happened.
  4. Qsilverrdc
    Aug 3, 2014
    34
    115ac is across a 5w 3ohm in series with this Device.
    A bridge rectifier taps in parallel with the device.
    It got hooked to 220ac and some smoke came out.
  5. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    That'l do it. ;)
    Max.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It's a 7mm 241v MOV.
    Will be easily available from digikey or element14.
    Qsilverrdc likes this.
  7. Qsilverrdc
    Aug 3, 2014
    34
    Ok..
    Thanks.. I think I see how its a TVR.
    I have included the circuit that this is in.
    Oh. I found that the 3 ohm resistor is open.
    Hope the squib and resistor are all that are wrong.
    So to anyone... what voltage is the DC motor.
    It rectifies at about ??? Half wave 170vdc peek.
    So Va to ground after bridge is ??
    This circuit runs a DC motor forward or reverse by rocker.
    I would like to know a little more.
    Rich
  8. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    If it is a SCR type bridge it will run a 90v motor on 120vac and 180v motor on 240v.
    Max.
  9. Qsilverrdc
    Aug 3, 2014
    34
    Trying to attach schem..
  10. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    90VDC motor.
    Max.
  11. Qsilverrdc
    Aug 3, 2014
    34
    Thanks for your help!
    Good to know.
    Rich
  12. Qsilverrdc
    Aug 3, 2014
    34
    After more checking I am now confident that this is a 240V TVR/MOV...
  13. Qsilverrdc
    Aug 3, 2014
    34
    Thanks for all your help. I was able to repair that board.:)
  14. ian field
    Distinguished Member
    Oct 27, 2012
    4,464
    792
    The "241" is probably the same old 2 digits and multiplier; 240V - would be a fairly generous margin for 110V mains.
    They have a bit of a tendency to shatter or disintegrate when they fail - but I'm not too sure just how bad the resin dipped variety can get before you can see visible signs.
  15. b1u3sf4n09
    Member
    May 23, 2014
    115
    14
    Here is the datasheet.
  16. Qsilverrdc
    Aug 3, 2014
    34
    There is another board I am working on fixing.
    The device is about .25" wide .12" thick and .35" tall.
    Silver. I'm pretty sure it's a capacitor of some kind.
    Can sort of see layers thru the end.
    Silver component on left..
    Can anyone tell for sure?
    Thanks.
  17. ian field
    Oct 27, 2012
    4,464
    792
    There are some pretty good clues in the screen print on the PCB.
  18. THE_RB
    Feb 11, 2008
    5,435
    1,305
    104 polyester cap = 0.1uF.
    In that size it's a 50v part.
