If i have 3 wires.. and ones a 5v wire and ones a ground.. if i put a jumper wire from the 2 wires with a .5 watt 3.3v zener diode.. would that lower the voltage of the 5v to 3.3v?
This is the second time I see the question: zener diode help The hiding of the automotive requirement will not help you. Whwn you try to post the same question again a ban may follow.
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics.
The following topics are regularly raised however are considered off-topic at all times and will results in Your thread being closed without question:
Any kind of over-unity devices and systems
Automotive modifications
Devices designed to electrocute or shock another person
