Zener Diode Circuit
Discussion in 'Homework Help' started by AD633, Jun 24, 2013.
  1. AD633
    Jun 22, 2013
    96
    The circuit of Figure load RL is powered by a voltage source VS which can take values ​​within a certain range of Vmin and
    Vmax.Considerando queVz = 9V, Vγ = 0.7V, PZ = 0.27W, IZmin = 3mA, IL = 10mA,determine Vmax and Vmin guaranteeing IL constant current (10mA)
    regardless of the value of VS.
    First i determined Iz max from Pz=Vz*Iz ,giving Izmax=33,3 mA
    Then for determing Vs min and Vs max i think i have to due the following meshes:
     Vsmin=R1(Izmin+Il)+9<br />
<br />
Vsmax=R1(Izmax+Il)+9
    My problem is that i dont know R1,and for determing R1 i have to know Vs..Do i have to due a system of equations for solving this?
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    The value of R1 has to be either selected or specified in order to solve the problem. R1 sets the total current flowing into both the load and the zener, so you select that value to make sure you have enough current at the lowest value of VS. The current through R1 is always going to be the sum of the zener current and load current.
  3. LDC3
    Apr 27, 2013
    920
    160
    How did you get 33.3 mA? I don't.
  4. AD633
    Jun 22, 2013
    96
    By doing Pz=Vz*Iz
    0,27 W= 9 V* Izmáx
    Izmáx=30 mA
    So for solving this i have to select a value for R1?The question does not specify any value for R1...
  5. LDC3
    Apr 27, 2013
    920
    160
    Now you have
    I1max = IZmax + Il
    I1min = IZmin + Il
    Since R1 is not specified, then the voltage needs to be a function of R1.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Vγ = 0.7V
    What is this?
  7. AD633
    Jun 22, 2013
    96
    Its the voltage drop across the diode when is forward biased.It does not seem to be much of a help for determing R1..
    So the answer would be something like:
    <br />
<br />
Vsmin=R1(3 mA +10 mA) +9 V<br />
<br />
Vsmax=R1(30 mA +10 mA) +9 V
  8. WBahn
    Mar 31, 2012
    18,093
    4,920
    Yes. Now you should try to do a couple of things:
    1) See if it now makes sense that you should be able to write these two equations down by inspection.
    2) In words, describe what each piece of each equation means.
    3) In words, describe what will happen if Vs is below/above this range.
    Now see if you can push your understanding a bit:
    4) What is the expression for the width of the allowed voltage range (the difference between the minimum and maximum voltages)?
    5) What does each people of that equation represent?
    6) What things does that equation NOT depend on?
    7) Do the answers to Q5 ans Q6 make sense (after pondering them a bit, if necessary).
