zener diode? ceramic capacitor? What is this?
Discussion in 'General Electronics Chat' started by ryanjohnlenz, Mar 18, 2015.
  1. ryanjohnlenz
    Mar 18, 2015
    Hi everyone-
    A bit out of my league here. Trying to figure out what this blue part is so that I can repair it--it's obviously been zapped (220 is a lot different than 120, it appears....).
    I thought maybe it was a ceramic capacitor, but the PCB board definitely shows a different symbol. A friend suggested a zener diode, but a quick image search showed nothing even close to this. Screen Shot 2015-03-18 at 6.41.16 PM.png Screen Shot 2015-03-18 at 6.41.39 PM.png
  2. djsfantasi
    Apr 11, 2010
    2,906
    879
    It's a metal oxide varistor or MOV. They are used for surge protection.
  3. DickCappels
    Aug 21, 2008
    2,774
    671
    There is an excellent chance that the things that components that the MOV was intended to protect are also damaged.
    Roderick Young likes this.
  4. ryanjohnlenz
    Mar 18, 2015
    Thanks, both of you. Spot on.
    Guess it's not much of a surge protector then, eh Dick? :)
    I'll fumble around with my multimeter and see if I can find any other damaged parts...
  5. wayneh
    Sep 9, 2010
    12,391
    3,246
    See F1? That's probably a fuse and it's likely blown. Was it on the back of the board or never installed?
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    probably a lightning strike near. static dosnt usually smoke thm like that. probably not a direct hit with lightning, a lot more would have been burnt.
  7. Brevor
    Apr 9, 2011
    282
    56
    The MOV is there for protection from voltage spikes. Your device should work without it. if not something else has been damaged.
  8. ryanjohnlenz
    Mar 18, 2015
    Well you guys are going to love this: Yes, there was fuse (F1) in there, which was blown from the first time the coffee grinder was plugged into 220 (instead of 110). I couldn't find a fuse, so I temporarily bypassed the fuse with an alligator clip (yes...I know...boy-genius here). Turns out the aligator clip must have also been bridging some other connection, because when I powered it up--poof, magic smoke.
  9. wayneh
    Sep 9, 2010
    12,391
    3,246
    Ah, the plot thickens as the smoke clears.
  10. ryanjohnlenz
    Mar 18, 2015
    :oops: Yes it was very exciting. My wife, feeling responsible for plugging it into 220v, even got to witness it. She's not an electrical whiz, but she did know enough to recognize that it was no longer her fault that the grinder may now be a very overpriced paperweight. Whoops.​
  11. PlasmaT
    Member
    Feb 19, 2015
    53
    8
    I do not think it was due any shorting of the alligator clips. Perhaps the MOV might have been rated just above 110V. But how did the other parts survive? :)
  12. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    This is one problem with MOV's they are often destroyed in the act of protecting the circuit, if tucked away out of site you may be not aware of it, and the next spike that comes along is not suppressed.
    It is usually a result of the MOV under rated or the energy of the surge voltage exceeds the MOV rating.
    Max.
