How Zener Diode is used as voltage regulator? Please explain with circuit diagram and in detail
No this is not an assignment.Is this an assignment? Homework?
I've read the Article from Electronics-Tutorials. But a sentence from there is confusing me. First there written the voltage across R is alwaysIn addition to Bertus' links, here is another.
http://www.electronics-tutorials.ws/diode/diode_7.html
V sub R is not the voltage across the resistor it is the Reverse Bias voltage ACROSS THE ZENER DIODE. V sub z has a fixed value for each diode. It will vary a little bit from diode to diode in a lot of "identical" diodes. V sub R in a given circuit will vary from zero to some negative value where the junction breakdown occurs. The purpose of the resistor in a zener diode regulator is to limit the current through the zener diode so that breakdown will NOT occur.I've read the Article from Electronics-Tutorials. But a sentence from there is confusing me. First there written the voltage across R is always
the same as the zener voltage, ( Vz = Vr ). And at last The supply voltage Vs must be greater than Vz . So this means Vs is always greater than Vs due to initial voltage drop in Resistance. So is my speculation is correct that Vs is always greater than Vs due to initial voltage drop in Resistance.
Yes it's clear now. Does temperature affect the working of Zener diode ? As lot of diodes are temperature dependance.V sub R is not the voltage across the resistor it is the Reverse Bias voltage ACROSS THE ZENER DIODE. V sub z has a fixed value for each diode. It will vary a little bit from diode to diode in a lot of "identical" diodes. V sub R in a given circuit will vary from zero to some negative value where the junction breakdown occurs. The purpose of the resistor in a zener diode regulator is to limit the current through the zener diode so that breakdown will NOT occur.
Does that clear things up a bit?
