Zener diode as a Shunt regulator
Discussion in 'General Electronics Chat' started by hasanz89, May 10, 2016.
Thread Status:
Not open for further replies.
  1. hasanz89
    Jul 10, 2014
    5
    I need help on 12 v adapter with 12-5-2A output Provided with 350 rms output using bridge rectifier. It used a mosfet irf 730 with 400 v what kind of zener utility to use if the desired output is 12-5-2A is 5.1 volt zener diode will satisfied circuit Thankyou
  2. crutschow
    Mar 14, 2008
    13,472
    3,361
    What is 350 rms output?
    Post a schematic.
  3. hasanz89
    Jul 10, 2014
    5
    the rms from 220 volt is 311 volt at rload bridge rectifier,but during the voltage test I found the D3 is alternate to positive?
    if the threshold of irf 730 is 2.0 volt so the drain voltage does not fall below the gate voltage by more than 2.0 volts
    I will try to post a scematics soon,thank you
  4. Alec_t
    Sep 17, 2013
    5,961
    1,133
    What is a "12-5-2A output"?
  5. hasanz89
    Jul 10, 2014
    5
    it's a voltage regulator generated a fixed output from a primer circuit using Mosfet and BJT to maintain a constant 12 volt and 5 volt output with 2 Ampere electric current
  6. hasanz89
    Jul 10, 2014
    5
    these is the primary circuit the input iss 220vac
  7. Lestraveled
    May 19, 2014
    1,957
    1,217
    This circuit is not isolated from the mains and thus forbidden on this forum.
  8. JohnInTX
    Jun 26, 2012
    2,392
    1,051
    Agreed. Closed. Transformerless power supplies are not allowed on AAC per the Terms of Service. If you can pursue the circuit after adding a transformer to isolate the circuit from mains, PM a moderator with the schematic and we will reopen the thread.
    Thanks for your understanding.
Thread Status:
