Z11,Z22,Z12,Z21 on CST MWS
GIGER
Joined Feb 17, 2015
Greetings!
If anyone is familiar with this program, please let me ask you something.
If I have designed 2 dipoles with 1 port at each one, in 1D results I have in Zmatrix the Z11,Z22,Z12,Z21.
Can you describe what does the program do in order to calculate these results, because i'm really confused.
That'd be a precious help.
Thank you!
Papabravo
Joined Feb 24, 2006
21,228
I'm not familiar with that one, but I have used EZNEC. That program uses numerical integration to solve differential equations that have as their solutions, the radiation patterns of antennas as well as their impedance parameters.
GIGER
Joined Feb 17, 2015
My basic problem is this:
I have an equation that i can calculate theoritically the Z parameters, but the calculated results with the simulated results are not equal.(not even close)
I think that the program short or open circuit some of the ports in order to do the simulations.
I found (i dont know if its true) that the Z12 on CST means that you have excitation in one of the two ports and the second one is open circuited.
is this true?
Papabravo
Joined Feb 24, 2006
21,228
That sounds right, but IIRC the reason we don't use Z parameters is because it requires open and shorted ports. We used s-paramters and the equipment just measured them without going through the gyrations.
Have you tried simulating something simple you know the answer to?
GIGER
Joined Feb 17, 2015
Nope... And i haven't found something useful telling about Z matrix and Y matrix.
If you think about a 2 port circuit my previous post maybe its true, but i want someone to confirm this.
