z transform of difference equations
Discussion in 'Homework Help' started by count_volta, Sep 18, 2010.
  1. count_volta
    Thread Starter Active Member
    Feb 4, 2009
    435
    24
    Hi, I am pretty new to Z transforms, I need some help.
    I have the following difference equation:
    y(n) +0.25y(n-1) - .125y(n-2) = x(n-1)-0.5x(n-2)
    y(0) = 0
    All I need to do is get the transfer function H(z) and find the poles and zeros.
    Here is my attempt:
    Taking Z transform of the difference equation:
    y(z) + 0.25*z^-1*Y(z) - .125*z^-2*Y(z) = z^-1*X(z) - 0.5*z^-2*X(z)
    Then the transfer function is:
    H(z) = (Z^-1 - 0.5Z^-2) / (0.25z^-1 - .125Z^-2)
    Then I have poles at Z = 0 and Z=-0.5
    Now to check myself I used matlab. The matlab answer is very different from mine. This is what bothers me. Here is the matlab code.
    numz = [1 -0.5];
    denz = [1 (1/4) (-1/8)];
    DiscreteSystem = tf(numz,denz,-1);
    DiscreteSystem
    Transfer function:
    z - 0.5
    z^2 + 0.25 z - 0.125
    pole(DiscreteSystem)
    ans =
    -0.5000
    0.2500
    So did I do something wrong, if so where? Thank you.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You wrote
    You missed a part ... the term with just Y(z)
    H(z)=Y(z)/X(z)=(z^-1-0.5*z^-2)/(1+0.25*z^-1-0.125*z^-2)
    or H(z)=(z-0.5)/(z^2+0.25*z-0.125)
  3. count_volta
    Feb 4, 2009
    435
    24
    LOL thanks, need to be more careful. I just needed confirmation that I'm doing it right. Especially whether or not I was taking Z transforms of the difference equation correctly. Glad all I did wrong was miss a term.
    Its also confusing how matlab expresses z transforms in terms of positive powers of Z. Have to go back and forth between the two versions to check my work. Lots of room for silly mistakes.
  4. count_volta
    Feb 4, 2009
    435
    24
    Now I need help taking the inverse Z transform. So I have the transfer function:
    H(z) = (z-0.5) / (z-0.25) (z+0.5)
    I need to find H(n). I did partial fractions on it and got:
    H(z) = ((-1/3) / (z-0.25)) + ((4/3) / (z+0.5))
    Then I look at a table of Z transforms and can't seem to find anything that matches. Here is a table of z transforms.
    http://cnx.org/content/m10119/latest/
    If only this was Laplace transform I could easily do it. I guess I need help with the math itself. Can anyone help me out please?
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
