(Z-Transform) How to show that y[n] = x[n] * h[n] turns into the Y(z) = X(z).H(z)?
Discussion in 'Math' started by krlngc, Nov 15, 2014.
  1. krlngc
    Dec 9, 2013
    11
    I'm trying to show that y[n]=x[n]∗h[n] turns into Y(z)=X(z)H(z) in Z-domain by first applying convolution then by taking the inverse Z-transform of the Y(z), stating that it's the same sequence after all. However, in power series expansion an extra term appears which kills the equation. You can find the question below; I added it as an image.
    I'd be grateful if you could help.
    Thank you
  2. krlngc
    Dec 9, 2013
    11
    There's a mistake on the 2nd line. I should've written x[m]
  3. WBahn
    Mar 31, 2012
    18,093
    4,919
    How about looking at the definitions of the Z transform and of convolution?
