Z-transform basic
Discussion in 'Homework Help' started by Anthony Quah, May 14, 2008.
  1. Anthony Quah
    Thread Starter Active Member
    Dec 1, 2007
    80
    hi guy,
    need help to explain about Z-transform basic. I am currenty study Digital Signal Processing (DSP), please view the attachment..it will make it clearer..thanks
  2. Caveman
    Apr 15, 2008
    471
    Those values are the givens for the problem.
    Each term is simply x(k)\delta(k-n) for a given k. So for x(-2), the term is x(-2)\delta(k-(-2)) = x(-2)\delta(k+2) = 1.5\delta(k+2), which is the first term in the answer.
    You only have to write 6 terms because all of the others are given as zero.
  3. mrmount
    Dec 5, 2007
    59
    7
    I think you ve misunderstood a bit. Are you asking how x(-2)=1.5, x(-1)=0.5, and so on ?
    If so, it is just an example function x(k) with a value of 1.5 and 0.5 at -2 and -1 respectively. And it is just substituted in the equation as Caveman has ponited out.
  4. Anthony Quah
    Dec 1, 2007
    80
    thanks for the help..^^ i really didnt see it..
