Z source inverter
Discussion in 'The Projects Forum' started by saurabh1234, Apr 9, 2012.
  1. saurabh1234
    Nov 13, 2009
    9
    hey guys,
    I am currently working on z source inverter for UPS applications. My problem is that in the shoot through state, the input current becomes unbounded because both the switches in the leg are shorted. if anyone come up with a solution to the above problem plz help.
    ParvathyDinu likes this.
  2. wayneh
    Sep 9, 2010
    12,379
    3,235
    You'll get better advice if you can post a schematic.
    You may also enjoy this paper.
  3. saurabh1234
    Nov 13, 2009
    9
    what i wanted to ask is dat in shoot-through state in a z source inverter...for whichever application, since both the legs are shorted..current is bound to increase as there is no resistance in the circuit at that time.what can be done to prevent the current from increasing?
  4. mhaskari
    Apr 15, 2012
    15
    hi
    My project is simulation of Z-source inverter!!!
    ]n Z-source, the switches of one leg can shorted in same time, that is the feature of Z-source.
    In shoot through state, the Z-source, equivalent the converter.Now with control time of shoot-through zero state, we can step up or down the voltage.
    My question:
    How control the time the shoot through zero state?
  5. saurabh1234
    Nov 13, 2009
    9
    shoot through duty ratio can be calculated by using the governing equations and can be implemented using a simple logic circuit. i can mail you the simulink model for simple boost control if u want.
    sanusielect likes this.
  6. mhaskari
    Apr 15, 2012
    15
    Thanks a lot.
    Can you create the signal with control time of shoot through in Fig 12?
    I produce the signal in Fig 11 but I can not control time of shoot through state.
    <SNIP>
  7. nitewind
    Apr 27, 2012
    Hi saurabh1234,
    Can you send me the simulink model for simple boost control?
    Thanks a lot
  8. syida
    Mar 15, 2014
    i am final year student and still in progress to complete my final project .. My title project is about z source inverter .. Can u send the simulink about z source with simple boost control? The simulation is very important to me graduate .. Help me please help me:(:(:
  9. syida
    Mar 15, 2014
    can you send me simulink z source inverter with simple boost inverter
  10. sanusielect
    Mar 28, 2014
    6
    Please i will appreciate if you can help me explanation of the governing equations and how to implement the PWM control circuit in SIMULINK block.
    Thank you
  11. sanusielect
    Mar 28, 2014
    6
    Thank you
  12. sanusielect
    Mar 28, 2014
    6
    Pls can u help me with the simulink control block for ZS inverter.
    Thank u
  13. sanusielect
    Mar 28, 2014
    6
    pls can u help me with pwm controlled block for zsi and the connection on the simulink block. My email is sanusielect@yahoo.com.
    Thank u
