Your Zip Code Or Other Country Mail Id
Discussion in 'Off-Topic' started by loosewire, Mar 10, 2012.
  1. loosewire
    Thread Starter AAC Fanatic!
    Apr 25, 2008
    1,584
    435
    Does any any other country use a zip code type of mailing Id.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    England has some strange method of attaching things like, "SW19" to an address, but I don't live in England so I don't know what those mean.
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    yes. canada, singapore, spain, philippines, and korea are some countries I've been to where I noted that there were postal codes. The philippines uses a postal code, plus they divide cities into smaller sections, called barangays, which are also part of the address. The addresses in korea are so convoluted that I hope you never need to send anything there; it surely will never reach it's destination.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    In holland we have a "postcode" system.
    The "postcode" consists of 4 numbers and 2 letters.
    The adress is completed with the housenumber and the extention.
    Inside a "postcode" there can be 24 houses.
    Bertus
  5. Markd77
    Sep 7, 2009
    2,803
    594
    The UK system makes sense once you get used to it. The code is something like M1 8XZ or BS8 9AB. The first letter (or two letters) represent an area (Manchester or Bristol in the above codes).
    The number after that divides the area into smaller patches (1 will be in the centre and then higher numbers farther out). The second part of the code divides the patches into streets or parts of streets.
    London needs so many codes that they use compass headings as the first part of the code.
    loosewire and Sparky49 like this.
  6. loosewire
    Apr 25, 2008
    1,584
    435
    What color is the Queen.
  7. VoodooMojo
    Nov 28, 2009
    503
    53
    caucasian.
    loosewire likes this.
  8. VoodooMojo
    Nov 28, 2009
    503
    53
    Markd77,
    before their passing, my parents address was
    4 magnay rd
    drayton, norwich, norfolk NR8.
    Has that numbering system been changed?
  9. Markd77
    Sep 7, 2009
    2,803
    594
    The Queen mostly lives in Buckingham Palace (postcode SW1A 1AA) so she is pale blue.
  10. Markd77
    Sep 7, 2009
    2,803
    594
    It's still the same NR = Norwich
    The full code would be NR8 6BT
    loosewire and VoodooMojo like this.
  11. debe
    Sep 21, 2010
    955
    185
    Here in Australia each town with a post office there is a post code. Mine is 5576, the first number designates the state.
  12. Georacer
    Nov 25, 2009
    5,151
    1,266
    In Greece, there's a 5 digit number designated to every area of some thousand people or so. In my previous, rural home, the postal code was 352 00. I don't know if it breaks down to some meaningful blocks.
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    Since UPS and FedEx, all of them do, even if they don't actually use it internally very often, other than census, etc.
    There was somewhere you could get a "Postal Code" CD for like $50, but now it is free online with UPS, USPS and FedEx if you have the address and just want to look one up.
    Databases hate Null fields, so everybody gets a postal code, whether they like it or not.
  14. R!f@@
    Apr 2, 2009
    8,793
    771
    Until recently, our post code makes no sense whatsoever.
    But now it's online and pretty good.
