Hey,
I designed the following circuit.
The resistors (R32, R33) and NTC thermistor have Resistance's tolerance of 1%.
I'd like to ask a few questions please.
1.
The ADC supports 12-bit resolution - does it mean that its max error would be 1/(2^12) = 0.024% ?
2.
The way which I tell the temperature is as follows:
The tolerance of B is ±3%.
T is the NTC Thermistor's temperature.
R is the thermistor's resistance, which I calculate using the ADC and the following formula:
To what extent of accuracy can I tell the temperature of the NTC thermistor, considering all the above data?
3. Would you consider this design good enough for temperature sensing?
Thank you very much
1.
2.
Thank you very much
