Your favorite breadboard cleaner?
Discussion in 'General Electronics Chat' started by wayneh, Sep 7, 2016.
  1. wayneh
    Thread Starter Expert
    Sep 9, 2010
    12,396
    3,246
    Any ideas for cleaning up a breadboard?
    I've found on this forum a number of contact cleaner alternatives such as WD-40 and low-water isopropyl alcohol (IPA), or both. Using IPA to remove the residual mineral oil left from the WD-40 seems popular. I have both on hand.
    My breadboard is old but not too bad. It's not badly corroded (the cats didn't have the pleasure of peeing into it), it's just used and a little dirty from that normal use.
    I'm starting a new project soon and my board is empty. I've already vacuumed out the grunge and now I want to freshen it up. I'm not interested in buying some super expensive magic spray.
  2. #12
    Nov 30, 2010
    16,705
    7,355
    You're supposed to clean them?:confused:
    I guess I would use soapy water and a hair dryer.
    Maybe followed by a day in the attic to dehumidify it.
    There's no flux. What could get in there except fingerprints and dust?
    If there's nothing exotic in it, don't use anything exotic to clean it.
  3. KeepItSimpleStupid
    Mar 4, 2014
    1,287
    225
    The ones I'm used to were plastic, pins and a paper backing. If you loose the paper backing, you'd have a bunch of pins to contend with.
    So, I'd go with something mechanical: air, brush etc. What to use to clean the plastic depends on the crud.
    Remember the old chemistry thich where you end with something that displaces water and evaporates quickly. e.g. IPA
  4. #12
    Nov 30, 2010
    16,705
    7,355
    I didn't know they have paper in them.:oops:
  5. wayneh
    Sep 9, 2010
    12,396
    3,246
    I'm pretty sure mine does have a stiff 'paper' backing.
  6. wayneh
    Sep 9, 2010
    12,396
    3,246
    I think a lot of the contamination is from, I think, occasionally using tinned wire instead of sticking to clean copper. So the crud is like the stuff that grows on the tip of a soldering iron. Black, oxidized crap. There's not much of it and I'd probably be fine just leaving it.
  7. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    Most of mine are from the 70's and I've never done anything more than blowing off dust.
  8. KeepItSimpleStupid
    Mar 4, 2014
    1,287
    225
