the output of the AY-3-8910 contains a transistor (that is how the circuit modulates the signal to allow an audible signal). The base pin of the transistor is modulated and amplied thought he transistor.
For an NPN transistor, the collector must be connected to a voltage more positive than the emitter for current to flow through it and allow the base pin to modulate the current flow.
If you connect either the emitter or collector pins to a capacitor, then no currnet can flow though it, the transistor is deemed to be "floating" at this point.
If you use the water valve analogy of a transistor, then mr. waterman can turn the valve (base) but since there is a cap on the end of the hose (capacitor), no water will flow and you cannot modulate the output signal proportional to number of valve turns. Simply, nothing happens.
Review the transistor pages of the eBook on this site.
