Yet another joule thief
Discussion in 'General Electronics Chat' started by takao21203, Dec 19, 2015.
  1. takao21203
    Thread Starter Distinguished Member
    Apr 28, 2012
    3,577
    463
    I've used a 2sc8550 pnp high current.
    Now I'm able to light 3 leds in parallel using 2 additional 47uh coils.
    The schematic is same as attached.
    I'm using this as night light for the ants.
    Mod Note: reduced image file size
  2. Dodgydave
    Jun 22, 2012
    5,130
    767
    So is it voltage free, cos i cant see the battery on the circuit diagram!! Looks like a modified Colpits oscillator,
    Whats the preset do, brightness control...
  3. ISB123
    May 21, 2014
    1,240
    531
    Didn't know Ford produces batteries...
  4. takao21203
    Apr 28, 2012
    3,577
    463
    just another is here
    Using a larger 10mH coil but wasnt so easy to get it working + needs fresh battery. With 1W LED tough which has a cooler.
    The reflector is needed as antenna for the base.
    Ive made the transistor plugable want to test several kinds, started with bc327 which maybe isnt very good for the base antenna variation.
    Didnt get any high voltage maybe the primary wire isnt right.
    Yes the other doesnt have the battery on schematic.
    And yes there are plenty ICs some which I even sell myself.
    But Ive learned a lot about transistors made 30 or 40 of these over the years.
    No they dont make batteries but sell licenses to put their logo.
  5. ian field
    Oct 27, 2012
    4,447
    791
    The local £ store has JCB branded batteries.
    IIRC: its a dozen for £1, zinc-carbon, so not really worth any price - highly unlikely to be approved by the firm that makes mechanical diggers.
    They also have half-dozen packs of Kodak Extralife alkaline - At the price, they compare with Duracell as long as you don't mind frequent battery changing.
  6. takao21203
    Apr 28, 2012
    3,577
    463
    The carbons aren't good no
    Some years ago I had rechargeable.
    I've spent 2 lantern batteries this year and bought lead 12v 18ah
    2 10w led chips attached with silicon on discarded pc tower metal plate.
    Dcdc converter mosfet from Hong-Kong.
    I've turned the voltage down so the plate doesn't heat too much
