Protection circuit activates after few seconds. Relay clicks. Display does not work. What elements are likely to be damaged due to overheating? What should I test?
Image gallery:
http://imgur.com/a/BDQNI
Image gallery:
Yes, you can assume that is the case, or you can actually READ THE MANUAL!!! It tells you how to override the protection mode so you can keep the unit on and display the protection errors.Everything is disconnected from the receiver. I can't use the self-diagnosis as display doesn't turn on.
Protection circuits are usually triggered by some kind of overload on the power supply. Really could be just about anything, but old electrolytics are always the first suspects.Protection circuit activates after few seconds. Relay clicks. Display does not work. What elements are likely to be damaged due to overheating? What should I test?
Image gallery:
Thread starter | Similar threads | Forum | Replies | Date |
J | Yamaha electone EL90 | General Electronics Chat | 3 | |
Yamaha Keyboard P-95 Cicuit Board Connector Name | Technical Repair | 2 | ||
R | Drum Machine Repair (Yamaha RX5) | Technical Repair | 0 | |
S | Yamaha PSR-31 ..#2 | Technical Repair | 0 | |
H | Yamaha RX-V361 receiver shutting off few seconds after powering on. | Power Electronics | 4 |
by Duane Benson
by Jake Hertz
by Jake Hertz
