Y transformer
Discussion in 'General Electronics Chat' started by DexterMccoy, Apr 18, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    I'm not sure if this transistor is two separate transformers
    Or it's One transformer
    But what kind of transformer has the primary side as a coil and the secondary coil is a Y to do phase angle voltage outputs X,Y,Z phase angle outputs?
  2. GopherT
    Nov 23, 2012
    6,303
    4,020
    Are you asking,
    -what a phase angle meter is used for?
    - how a phase angle meter works?
    - how to to use a phase angle meter as a transformer?
    - something else
  3. DexterMccoy
    Feb 19, 2014
    429
    no , the schematic I drew , is this two separate transformers? or One transformer?
    The Primary is what kind of coil?
    The Secondary is what kind of coil?
    Is this ONE transformer that has these two kinds of coils in one transformer package?
  4. GopherT
    Nov 23, 2012
    6,303
    4,020
    Yes , it definately is.
    The secondary appears to be a Y winding and the primary does not. As drawn, I can't tell if the winding is a helix with anti-clockwise rotations or non-anti clockwise windings. In either case, if the Y windings are, in fact, secondaries, then they must be one transformer because secondaries do not function well without a primary. I am trying to think where I may have come across a transformer with only secondaries and it made me think of a 120 to 12 to 12 to 120 volt isolation transformers where you have the secondaries of two identical transformers connected and the primaries if the second transformer is really the secondary winding but since it is revers, it is really the primary. If the whole thing were encapsulated, you would really have two sets of primaries and no visible (or usable) secondary. But that doesn't help answer your question at all.
    In the end I completely agree with you, it is a Y.
  5. DexterMccoy
    Feb 19, 2014
    429
    What is a transformer called when you have a secondary winding as a Y winding? but the primary is not ?
  6. GopherT
    Nov 23, 2012
    6,303
    4,020
    It depends. Is it for electrical power transformation. is it for sensing or is it for mechanical generation of electricity or, lastly, is it for electrical generation of mechanical power?
  7. DexterMccoy
    Feb 19, 2014
    429
    It has a Knob variac pot
    The pot changes the phase shift , phase degree
    The primary coil is 26 VAC , the secondary is changing the phase angle
    What kind of transformer is this called?
  8. GopherT
    Nov 23, 2012
    6,303
    4,020
    Interesting details but you haven't answered my question above. Your answer will determine what your device is called.
  9. DexterMccoy
    Feb 19, 2014
    429
    Yes I think so
    It just changes 26 VAC in phase into 26 VAC phase degree/shift , depends on the variac dial
    NO
    NO
    It just changes an 26VAC input in phase voltage into a 26 VAC that can be between 0 degree to 360 degrees inphase or out of phase by the Y transformer coil
  10. GopherT
    Nov 23, 2012
    6,303
    4,020
    If that is what it does, there must be some additional coils in the device that are missing from your drawing. Does it work the same way when loads are connected (not just tiny loads).
  11. DexterMccoy
    Feb 19, 2014
    429
    No it's just those 2 coils
    One primary and One secondary coil that is a Y coil , that has 3 outputs , X, Y, Z outputs , this is the phase shift outputs
    Yes it does work with a load
  12. GopherT
    Nov 23, 2012
    6,303
    4,020
    Google up "quad booster", or quadrature booster
  13. DexterMccoy
    Feb 19, 2014
    429
    No that's not it
    It's very low voltage 26 VAC, not for Power Electrical transformers
    The primary is normal coil
    The Secondary is a Y coil , that has 3 outputs , X, Y, Z
    Their is a Variac Pot , to adjust the Phase angle of the secondary
  14. nsaspook
    Aug 27, 2009
    3,009
    2,352
  15. DexterMccoy
    Feb 19, 2014
    429
    How does a synchro transmitter be able to be adjust from zero degrees to 360 degrees?
  16. nsaspook
    Aug 27, 2009
    3,009
    2,352
    This is the best source for syncro information.
    http://www.hnsa.org/doc/neets/mod15.pdf
    kubeek likes this.
  17. BillB3857
    Feb 28, 2009
    2,402
    348
    I'm not supposed to be here, but I will ask anyway.... Does it operate on 400Hz?
    shortbus and GopherT like this.
  18. Lundwall_Paul
    Oct 18, 2011
    222
    19
    The word servo comes to my mind. Saw a lot of these in old radars that the AF had back when I was in.
  19. Lundwall_Paul
    Oct 18, 2011
    222
    19
    nsaspook curious what branch of the service you were in? I worked on automatic tracking radars in the USAF.
  20. nsaspook
    Aug 27, 2009
    3,009
    2,352
    USN. IRT to servos I worked on radar (antenna and repeaters), fire-control, RF directional antenna systems and just anything else that needed to be fixed including the old analog DRA system that was a mechanical monster of servo inputs, motors and dials.
    http://www.globalsecurity.org/military/library/policy/navy/nrtc/14308_ch9.pdf
Thread Status:
