Y DC jack has 3 lugs?
Discussion in 'General Electronics Chat' started by mxabeles, Apr 27, 2009.
  1. mxabeles
    Thread Starter Active Member
    Apr 25, 2009
    182
    I want to solder up a DC jack for an adapter but I am confused. The plug from the adapter seems to have two points of connection, positive and ground. Why then does the jack have THREE lugs?
    I have tried researching this thoroughly but with no avail.
    Thanks,
    Max
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Can you post a picture?
    Is it for input?
    The third lug may be for switching.
    Greetings,
    Bertus
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Some DC jacks have a 3rd connection that can be used to switch between internal battery power and external "wall-wart" power.
    It can also be used to apply a ground to discharge internal filter capacitors rapidly, in case the circuit is logic level and operation at low voltage is not desireable.
    You'll need to use a meter with a plug inserted into the jack to determine which terminals are "live" when connected.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    Also, it could be a stereo jack.
    Ken
  5. mxabeles
    Apr 25, 2009
    182
    "yeah, that is the best solution"
    simple thanks
