-Y and Y- transformation
Discussion in 'Homework Help' started by gicode0823, Feb 18, 2012.
  1. gicode0823
    Feb 8, 2012
    31
    I understand that there is no current though the 1KΩ resistor but I don't understand why the 1.5KΩ resistor doesn't have current thought them...
    is it because of KVL? since there is no voltage across the 1.5kΩ resistor thus the current must be zero?
  2. Vahe
    Member
    Mar 3, 2011
    75
    9
    The 1.5k resistor does not have any current going through it because it seems to be shorted -- both terminals of the resistor are tied together.
    --Vahe
  3. gicode0823
    Feb 8, 2012
    31
    What does the shorted exactly mean? or what happened when shorted?
  4. justtrying
    Mar 9, 2011
    329
    404
    other components create a path for current so that it bypasses the component - look closely at the nodes (a,c,d) and how it is wired, do you notice anything?
    gicode0823 likes this.
  5. Vahe
    Member
    Mar 3, 2011
    75
    9
    As I said in my message, "shorted" means that both terminals of the resistor are tied together and therefore there is no voltage across the resistor. As a result the current through the resistor is zero due to Ohm's law
    i=V/R=0/R=0A.
