y and star motor wiring . confused
Discussion in 'General Electronics Chat' started by t00t, Jan 22, 2015.
  1. t00t
    Jan 22, 2015
    56
    ok so i have been readin up about AC squirrel cage motors . I am really confused as to the connections used for these motors .When do i use star connection and when do i use delta connection ? And how do i see from a motor's information plate which connection should i use . And if a motor is to be connected in star if i change it to delta will the motor be blown up ?
  2. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    It depends on the individual motor how it is intended to be used, but generally the motor is dual voltage, e.g. 220/350 and the Star connection would be for the higher voltage and the Delta for the lower voltage.
    It should be labeled at the connections something like U1 V1 W1 & U2 V2 W2 the three sets of windings.
    http://www.usmotors.com/Connections/Connections.htm
    Max.
  3. t00t
    Jan 22, 2015
    56
    Is there any difference in motor speed rpm in star and delta connections ?
  4. crutschow
    Mar 14, 2008
    13,508
    3,385
    No. The speed is determined by the line frequency and the number of motor poles ( with it being slightly affected by the load).
  5. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    RPM is 60 x Hz/#pole pairs. e.g. 60x60Hz/1pp = 3600-slip frequency =~ 3520 rpm.
    Max.
  6. t00t
    Jan 22, 2015
    56
    Thanks for the answers so far .
    One last question . For the motor plate attached below . Can i know if i can connect both y and delta connection ?
  7. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    380v in Delta, 440v/480v in Star.
    One or the other.
    Max.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes - the nameplate is showing both connections are possible. You connect the links on the terminal block as shown in the diagram for either case. You have to also take note of the rated voltages in each case.
  9. t00t
    Jan 22, 2015
    56
    If the power coming from my country is a 3 pin plug 240v . Does means in 3 phase i get 360v and should connect in delta ?
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    My next question is - "Are you a licensed electrician in your country?"
    If not, then unfortunately our conversation is concluded.
    cmartinez likes this.
  11. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    You would need to supply more information on the type of supply you have, if it is a residential supply it is most likely 240v 1phase neutral and ground, if so the 3 phase would be 408v .
    You can run a motor from a VFD, this converts the 1phase to 3ph for motor control, but 240v will be too low for that motor.
    Max.
  12. t00t
    Jan 22, 2015
    56
    I am not an electrican. My degree is in chemical engineering . Thus i know nuts about electrical engineering :(. Tried to google but still unsure .
    Anyway may i know how is the calculation for 3phase voltage .
    Oh and yes its 240v output from the socket .
    Thank you.
  13. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
