XOR Neural Network Problem
Discussion in 'Embedded Systems and Microcontrollers' started by grantm, Jan 7, 2013.
  1. grantm
    Jan 7, 2013
    I have written an Artificial Neural Network code for a PIC microprocessor. The idea is to expand the code later into a forecast model for time series prediction and later implement the same model on a PLD platform. My model is a feedforward network that use back propagation as a learning method and was written for the Pic24F series microcontroller using the latest MPLABX development environment and associated libraries (16bit language tools ): 2 input nodes, 2 hidden nodes and 1 output node. Bias nodes were inserted. The idea is to first test the learning algorithm using the classical XOR problem. A data set is loaded:
    float DataSet[12] = {0,0,0,0,1,1,1,0,1,1,1,0};
    for which the first two bits are inputs and the last bit the expected output. The input is propagated through the network with the random initialise weights..
    float w[10] = {0.0,0.2,0.5,0.1,0.6,0.3,0.4,0.7,0.2,0.8};
    The output is then determined using:
    float CalculateOut(void)
    Whilst the error is greater than 10%, a back propagation learning algorithm seeks to correct: void Learn (void)
    The delta output is calculated for the output node and two hidden nodes. The output is simulated by means of the main loop. I used a variable watch to observe all the outputs (IDE environment). I am aware that the XOR is not linearly separable. The problem is that during the verification only two conditions are correct. The error is really high for conditions {0,0} and {1;1}. I have tried to get the code working for a while now but proved to be unsuccessful. I would be grateful if you can offer some guidance.
