I was wondering if an XOR gate can be used with reversing polarity ..........I am also using a 24vdc power source if I reduce the input power to say 5vdc going into the XOR Gate how can I step it back up to 24vdc on the output side of the XOR Gate
What do you mean by "reversing polarity" above?I was wondering if an XOR gate can be used with reversing polarity ..........I am also using a 24vdc power source if I reduce the input power to say 5vdc going into the XOR Gate how can I step it back up to 24vdc on the output side of the XOR Gate
I am using an L293DNE H-Bridge to run a electromagnetic coil I need to install an XOR GATE just before my coil to avoid any issues with multiple power switches Most of the XOR Gates seem to have an operating Max signal of 5.5vdc so I need to reduce this signal from 24vdc to 5vdc then back to 24vdc in order to energize the coil.................really I dont know what I am doing so I hope this makes senseYou can also use an open collector buffer pulled up to 24V. In order to actually reverse polarity, you'll need something like an H-Bridge between you logic and your load.
It makes no sense at all. Please post a drawing of your circuit and a detailed description of what your objective is. I don't know what avoiding "issues with multiple power switches" means. Explain your issues in detail.really I dont know what I am doing so I hope this makes sense
Are you trying to have,say, five switches such that any switch can be used to energize/de-energize the coil?I am using an L293DNE H-Bridge to run a electromagnetic coil I need to install an XOR GATE just before my coil to avoid any issues with multiple power switches Most of the XOR Gates seem to have an operating Max signal of 5.5vdc so I need to reduce this signal from 24vdc to 5vdc then back to 24vdc in order to energize the coil.................really I dont know what I am doing so I hope this makes sense
The H-Bridge drivers are for the coil the coil operates on 24vdc but it needs to reverse polarity in order to advance the clock handsAre SW4 and SW5 mechanical switches or relays or what?
Are the H-Bridge drivers just being used to add current drive capability to the Arduino outputs (i.e., act as buffers)?
What is the behavior that you WANT to have happen in the diagram as opposed to the undesirable thing that IS happening?
ok I want one arduino board to be on at all times lets call that board "A" and the secondary board "B" when board "A" is on "B" would be off to the coil via one of the switches when "B" is on board "A" would be off again via a switch ..........now if both switches happen to both be closed at the same time it burns up the H-bridges and I dont want to have to change fuses if this scenario happens I would like logic gates to stop all power coming from either switch if they are both closed at the same time............I really hope this make some sense I am terrible at explaining thisWhat do you mean by "protect that set up"?
What do you mean by "in-case both arduino boards are powered up at the same time"? Does in matter if they are both powered as long as one of the two switches is open?
What bad thing happens with how you presently have it shown? Is the problem one H-Bridge output contending with another H-Bridge output?
What behavior do you WANT to have happen if both arduino boards are powered up at the same time? Do you want the coil to energize as long as one of them is trying to energize it? Do you want the coil to energize only if both of them are trying to energize it? Do you want changing the state of either arduino to change the state of the coil?
I'm not going to ask again. What do you WANT this thing to do? Be explicit.
Why not have only board A control the H-bridge and when B wants to change the state, it is sends a signal to A, which changes the state.ok I want one arduino board to be on at all times lets call that board "A" and the secondary board "B" when board "A" is on "B" would be off to the coil via one of the switches when "B" is on board "A" would be off again via a switch ..........now if both switches happen to both be closed at the same time it burns up the H-bridges and I dont want to have to change fuses if this scenario happens I would like logic gates to stop all power coming from either switch if they are both closed at the same time............I really hope this make some sense I am terrible at explaining this
I don’t know.......... I need to find someone local to help me with this.......... this is way beyond my level of expertise and I need to get this project finishedWhy not have only board A control the H-bridge and when B wants to change the state, it is sends a signal to A, which changes the state.
Thats it all this time it was that easy all I needed to do was connect them before the H-bridges and not after and run the 24vdc externally and not thru the arduino itselfThis is not a difficult thing to do. The XOR gates need to be connected between the controllers and the H-Bridge. Connect both controller outputs to the XOR gate, and the gate outputs to the H-Brindge drivers. When both controllers try to drive at the same time, the gate outputs will be off, and thus drivers won't be driven.
By keeping the gates in the digital part of the system, and not at the motor drivers, you don't need to worry about input signal voltages being too high.
Once agian, a drawing and detailed explanaiton of what you intend to would help us to help you. You make it harder for everyone by not providing what we have asked for.
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Jake Hertz
