Good Day All.
I have a XFX 630i (MG-63MI-7109) that fails to power up.
I am testing this board with good known working PSU, CPU, Memory, ect.
With eveything connected, when you press the power button eveything powers up for a split second, and the PSU led go's from green to red.
If I discount the 4pin CPU power connection, and press the power button the system fires up, but there is no post.
With eveything disconected, I used my Digital Volt Meter to test the 4pin CPU power connection, and it's a dead short.
There are not poped caps or burnt parts.
As it is quite hard to test mosfet's in circuit, I desided to remove all 9 of the CPU mosfet's.
Once I removed all the mosfet's I retested the CPU power connection, and the dead short is no more.
So one or more of the 9 mosfet's had got dead short.
I am trying to find the full datasheets for the mosfet's so I can get somthing that is compatible.
So far this is what I have been able to find out about the mosfet's.
http://products.niko-sem.com/index_...rod_list&cat=24
Part Number: P70N02LDG
Package: TO-252
Configuration: Single
Type: N
VDS (V): 25V
VGS (±V): 20V
VGS(th) max: 3V
ID (A): 65A
RDS(on) mO max @ 4.5v: 15
RDS(on) mO max @ 10v: 8.5
Ciss typ.(pf): 1200
Crss typ.(pf): 350
Qg typ.(nC): 25
Qgd typ.(nC): 10
Part Number: P0903BDG
Package: TO-252
Type: N
VDS (V): 25V
VGS (±V): 20V
VGS(th) max: 3V
ID (A): 50A
RDS(on) mO max @ 4.5v: 16
RDS(on) mO max @ 10v: 9.5
Ciss typ.(pf): 1200
Crss typ.(pf): 350
Qg typ.(nC): 25
Qgd typ.(nC): 10
There are also four caps near the mosfet's, and they are Sanyo 1000uf 16v, I am going to replace them as well.
Can anyone please help and or advice me where in the UK I can buy the same or compatible parts needed to repair this motherboard.
Thanks for your time.
Best Regards.
Package: TO-252
Type: N
VDS (V): 25V
VGS (±V): 20V
VGS(th) max: 3V
ID (A): 65A
Ciss typ.(pf): 1200
Crss typ.(pf): 350
Qg typ.(nC): 25
Qgd typ.(nC): 10
Package: TO-252
Type: N
VDS (V): 25V
VGS (±V): 20V
VGS(th) max: 3V
ID (A): 50A
Ciss typ.(pf): 1200
Crss typ.(pf): 350
Qg typ.(nC): 25
Qgd typ.(nC): 10
Best Regards.
