XC95288XL, Alternative replacement chip.
Discussion in 'General Electronics Chat' started by Techmasteruk, Oct 13, 2016.
  1. Techmasteruk
    Oct 13, 2016
    15
    Hi all,
    I'm trying to replace this chip (Xilinx-XC95288XL-PQ208CMN0409) on my device, however I couldn't find a replacement parts with the exact same module number. Is there's any current module that I can replace this chip with ?
    Many thanks,
    Imad
    Moderators note : rescaled image and showed as full image
  2. MrChips
    Oct 2, 2009
    12,635
    3,454
    It is an XILINX XC95288XL.
    You can find a replacement but how are you going to program it?
  3. Techmasteruk
    Oct 13, 2016
    15
    Thanks MrChips
    Hmmm, program it ! Is it not as simple as taken the old one out of the circuit & install the new one ?
  4. MrChips
    Oct 2, 2009
    12,635
    3,454
    Not a chance!
    It is programmed with proprietary information.
    Techmasteruk likes this.
  5. Techmasteruk
    Oct 13, 2016
    15
    I've have contacted the device manufacturer & asked if they could possibly supply a pre programmed chip.
    Well spotted MrChips.
  6. Techmasteruk
    Oct 13, 2016
    15
    I've received a reply from the company today & I quote,
    "Unfortunately we are not able to help you, as we do not have any pre-programmed chips."
    I was wondering if I install the new chip then update the firmware of the device would that help ?
  7. Techmasteruk
    Oct 13, 2016
    15
  8. Sensacell
    Jun 19, 2012
    1,183
    276
    Probably not.
    Without boot loader code already installed in the chip, no firmware upgrade will work.
    Edit- oops! it's not an MCU, but problem remains the same.
  9. Techmasteruk
    Oct 13, 2016
    15
    Thanks Sensacell,
    How about if I backup the old software ?
    Got this information from the instrument user manual.
    Quote
    "As an option it is possible to upload a backup of the software installed in the MSD. Selecting the checkbox in the area ‘Backup old software’ will enable the input field making it possible to specify a destination filename for the backup file. This backup file can only be installed into an MSD of the same type."
  10. GopherT
    Nov 23, 2012
    6,310
    4,031
    @Techmasteruk
    How did you manage to diagnose the Xilinx chip was bad?
  11. Techmasteruk
    Oct 13, 2016
    15
    Hi GopherT,
    The image on instruments freezes or got distorted, the audio signals path get messed up also the chip get very hot then it cool down for a minute & hot again. Is this a sign that the chip is failing ?
  12. GopherT
    Nov 23, 2012
    6,310
    4,031
    If I were looking, I would be hoping that the "brain chips" (microcontrollers and fpga chips) with firmware would be the last resort solutions. I would make sure everything else worked.
    What is this Device that you are working on and what fails?
    Model numbers, description of the problem, ...
    This thread is more like we are solving your solution rather than solving your problem.
