Xbox 360 Controller Broken Wire!
Discussion in 'The Projects Forum' started by ritam2538, Mar 1, 2016.
  1. ritam2538
    Feb 28, 2016
    My Xbox PC Controller's cord has broken from inside and by opening it I can say I can fix it using a solder but I don't know where to solder the wires. I have given some pictures, can please anyone tell me where the 5 wires will be? Thanks for anyone who helps!
  2. TheButtonThief
    Feb 26, 2011
    219
    38
    Have you looked inside a working controller?
  3. ritam2538
    Feb 28, 2016
    no
  4. TheButtonThief
    Feb 26, 2011
    219
    38
    maybe start their.
  5. mcgyvr
    Oct 15, 2009
    4,793
    976
    Google images...
    "xbox wired controller pcb"
    plenty of pictures showing the wire locations..
  6. Evanguy
    Member
    Dec 21, 2014
    81
    8
    this thread of yours should help, find where the 5 pin connector would/should be soldered on the board and then solder your wires in place.
    there is a pic in the thread you already made. also if you google "xbox controller wiring" im sure loads of pics of opened up controllers will be there
    http://forum.allaboutcircuits.com/threads/xbox-360-controller-circuit-problem.121356/
    here is the pic
    http://forum.allaboutcircuits.com/attachments/20160224_182424-jpg.101512/
    the copper shield wire and Black are tied together.
    then a space "empty pin"
    then RED, WHITE, GREEN
    so five wires to four solder points, im sure just rubbing your hand over the broad will show where the broken wires came from, there should be bumps from where the 5 pin connector was removed and the wires were directly soldered to the board
