xbee with fpga
alex warne
Joined Feb 10, 2012
13
hi
i want to transmit and receive data using xbee and uart in altium and also using xctu. can anyone help me to write c code and schematic diagram for this research.
Thank you
Sure, what is your question?
You will want to learn a bit of HDL (Verilog or VHDL) to program the FPGA.
I don't know much about xbees, but it looks like they communicate over standard protocols... i2c, spi, uart, etc which are fairly easy on FPGA. Have a look at opencores.org for some free cores to get you started
alex warne
Joined Feb 10, 2012
13
Hi
i am using an altium nb3000. i want use fpga uart with xbee as a receiver i need a schematic diagram and how to program it with Vhdl.i need some suggestion .
Thank you
alex warne
Joined Feb 10, 2012
13
i need to use altium nb3000 uart or use as a serial port which will connected xbee to receive data from other xbee. i need to program it write a schematic .
thank you
kubeek
Joined Sep 20, 2005
5,795
I didn´t really understand that. So you want a connection in the fashion uart->xbee->xbee->uart ? What does fpga have to do with that?
kubeek
Joined Sep 20, 2005
5,795
I still don´t see why you need that fpga board when you should be able to connect the serial line from the pc straight to the xbee.
alex warne
Joined Feb 10, 2012
13
i am trying to use uart in fpga board which will be connected to xbee .i am trying to do using vhdl program and schematic a new approach .
takao21203
Joined Apr 28, 2012
3,702
I don't think FPGA works like you ask on a public forum "draw me a schematic".
The software required is very complex and so is the technology.
There are not so many people actually who can use FPGA at all.
90% FPGA developement is not hobby/individual users/beginners.
There are some websites with related topics, but not that many.
If your altium nb3000 evalution board does not contain an USART example, then it's a poor evalution board.
