Xbee antenna; outside box
Discussion in 'General Electronics Chat' started by aamirali, Aug 15, 2014.
  1. aamirali
    Feb 2, 2012
    415
    I have made a board on which xbee is connected. it communicates with another xbee, 3meters away from it.
    Now I have to seal the box. box is made of delrin. I have left small opening from where antenna can come outside. I have to sela the box, since weather is harsh, low as -10C.
    I am using xbee with wire antenna:
    http://www.digikey.com/product-detail/en/XB24-AWI-001/XB24-AWI-001-ND/935965
    1. I will fill entire circuit with potting material to make it weather proof. My question is how much antenna height should I keep ouside the box.
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    for a plastic box, none. the way to test for absorption of rf in plastic or potting terial is to put some in a microwave, along with a half cup of water, and run it a while, if it heats up, it absorbs rf energy.
  3. aamirali
    Feb 2, 2012
    415
    That plastic box is tied over long metallic pipe.
    Other box, which is also plastic to which first box communicate with xbee, is also tied over metal pipe?
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Monopole antennas (1/4 lambda or colinear) should be mounted orthogonal (not parallel) to a metallic ground plane. In this case, the ground foil on the pcb is likely parallel to the pipe, so the Monopole should stick up...
    If you have two, I would make sure that the two antennas are in the same plane. Crosspolarization results in a 20db signal loss...
