Hi
I have an rfid reader (http://media.digikey.com/pdf/Data Sheets/ThingMagic PDF's/MERCURYDevKit.pdf) with these specifications(as seen in datasheet): • In: 90-264 V, 0.4 A, 47-63 Hz • Out: +9 V @ 1.4 A • Max total output power: 12.6 W I would like to create an external battery module instead of connecting the reader to a wall. I would like to have some precisons on how to do it, which battery to choose and how long would the battery last ( I would like it's the run-time to be at least 12h)?
Thank you very much
Thank you very much
