New to the site but here goes!
I am looking to create a system that can indicate the position of a desired item using an X Y Z Coordninate principle. Still in the dark.....So am I.
To elaborate, I have been trying to find a method of showing were an desied item is in a 2m x 0.5m square. I first though of attaching a transmitter to the item and then putting a pair of recievers in each axis ( X Y and Z ). It would then be a case of scaling the output of all 6 recievers. My thought process behind this is that the readings at each reciever will never be the same as you move further towards and/or away from each reciever. Is this a correct way of thinking about this?
If anybody can advise if I am on the right track and/or just wasting my time I would be much obliged.
