Wye vs Delta Loads
Discussion in 'Homework Help' started by filemod, May 26, 2008.
  1. filemod
    May 26, 2008
    If I use a Y source and 3 lamps. One time I connect the load in delta, the other time in wye. I measure the power and the power in the load in delta is three times bigger than the power from wye. How come?
    Anyone have a link where they explain this or even more differences between delta and wye?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  3. Digi Dave
    Member
    Apr 25, 2008
    26
    When you connect the loads in "Star" format Y, the voltage is approx 230 Volts across the load because of the neutral, but when connected in "Delta" the supply voltage is appx 415 Volts across the load because there is no neutral but "Two phases"..
  4. delta
    Jun 22, 2009
    The reason why the load side (delta) is three times bigger than the power from the wye, because of the transformer turn ratio ( the square root of 3) and also the phase differences. One side usually lead by 30 degree out of phase from the other side according to there design.
  5. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
