WYE/DELTA Transformer and load lab
Discussion in 'The Projects Forum' started by Chris Russell, Oct 8, 2014.
  1. Chris Russell
    Oct 8, 2014
    Need some thoughts/suggestions on tasks/evaluations to assign for the attached photo.
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    480 Vac will kill or damage you quickly. I say:
    - Clean up the wiring so the paths are easy to see.
    - Put a sheet of plexiglass over it.
    - Bring connections out to test points in the plexiglass.
    - Put an emergency kill switch in an accessible location.
    In fact I would not use 480 at all. I would drop the Vac down to 10 volts.
    Students are stupid and this looks like a death trap.
    Chris Russell likes this.
  3. Chris Russell
    Oct 8, 2014
    Thank you very much!
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    if you bring it down to 12 volts, what was 120 is now 12, what was 480 is now 48. might make it easier to interpret the real world values.
  5. Lestraveled
    May 19, 2014
    1,957
    1,218
    Download a copy of MIL-HDBK-454 (any version). It is a guide for building electronic equipment that is safe to use.
  6. Chris Russell
    Oct 8, 2014
    I need to keep it at 480v as this is what the students will be working with when they graduate and I need it to be as realistic as possible. Kind of looking more for suggestions on lessons to teach using this mock-up.
    Thanks, Chris
