Wye & Delta Transformations
Discussion in 'Homework Help' started by Student01, Mar 7, 2010.
  1. Student01
    Thread Starter Active Member
    Apr 15, 2009
    35
    [SOLVED]
    Hi all,
    I'm working on the following question.
    [​IMG][​IMG]
    It's under the heading of "Wye & Delta Transformations" in the textbook. I've attempted it a couple of times, but can't see where I'm going wrong.
    I transform the middle Wye configuration into a Delta with resistors 140, 70 and 35 Ohms. I then reduce resulting circuit to get an effective circuit resistance of 33.793 Ohms. This produces a final answer of 0.710 A.
    The textbook says 0.9974 A is the correct answer.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Your first reduction of the wye part is correct - at least with respect to the element values.
    You've obviously gone astray after that. You would do better to show the subsequent working - particularly showing a network drawing so that your work can be checked.
    The book answer is correct.
  3. studiot
    Nov 9, 2007
    5,005
    515
    It is very easy to associate the wrong leg of the delta or wye in the transformation.
    Label the nodes, rather than the resistances and refer to the resistance between two nodes.
    You could try using the other wye in the diagram for practice and see if you get the same answer.
    I confirm TNK findings.
  4. Student01
    Apr 15, 2009
    35
    The rest of my working is, as follows (Starting from top-right of transformed circuit and working around the delta network clockwise):
    Combining branches of delta configuration with right-most branches of circuit
    60 ohms // 140 ohms = 42 ohms
    35 ohms // (20 + 50) ohms = 23.333 ohms
    Adding 2 sets of newly combined resistors in series
    23.333 ohms + 42 ohms = 65.3333 ohms
    Adding in parallel with remaining (leftmost) branch of delta configuration
    65.333 ohms // 70 ohms = 33.793 ohms
    Io = 24V / 33.793 ohms = 0.710 Amps.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Does your circuit look like that attached?
  6. Student01
    Apr 15, 2009
    35
    ... no, I have the 35 ohm and 70 ohm switched around. Hmmm. That is likely to be the problem.
    Thanks for your help, t_n_k. :)
