Wye Delta Transformation finding equivalent resistance Help
Discussion in 'Homework Help' started by Atif12, Nov 27, 2012.
  1. Atif12
    Nov 27, 2012
    I need help in this one Assignment Question. I have tried to solve it but could not succeed in it. After applying one transformation from wye to delta or delta to wye the circuit is getting very complicated.
    Can anyone can help me in this one question?
    I would be very grateful
    Regards,
    Atif
  2. atferrari
    Jan 6, 2004
    2,668
    784
    You need to start somewhere, any place but start.
    If this could inspire you, look how I did it once, here
    The pdf shows the whole process. Even the maths for that case.
    Buena suerte.
  3. The Electrician
    Oct 9, 2007
    2,301
    338
    Are you required to use Wye-Delta transformations to solve this problem, or can you use some other method?
  4. Atif12
    Nov 27, 2012
    I have to solve this question only through Wye-Delta transformation
  5. atferrari
    Jan 6, 2004
    2,668
    784
    Hola Atif,
    Could you show how many steps you did before finding it complicate?
    Have you even looked at what I suggested?
    Just by looking at your problem, less than 90 more than 10.
  6. The Electrician
    Oct 9, 2007
    2,301
    338
    Just by looking, it's less than 80 and more than 40.
  7. atferrari
    Jan 6, 2004
    2,668
    784
    Willing to bid closer but he still has to do something. :D PM on the way.
  8. atferrari
    Jan 6, 2004
    2,668
    784
    Hola Atif. Any progress from your side?
    If you show me the first transform (valid one) I would show the second one. The maths will be all on you.
    Do you agree? If you like we could try to complete the whole thing that way.
    Last night I worked out the complete solution by hand in 1h 40m.
    Just a tip that is rarely explained: delta to wye creates resistors to be added and wye to delta creates resistors that would be in parallel with the existing ones.
    If you proceed carefully, you will arrive to the right result.
