Wye-Delta Three Phase Circuit
Discussion in 'Homework Help' started by bobby19, Aug 14, 2007.
  1. bobby19
    Jun 3, 2007
    13
    In the attached file, the question asks to find the three line currents. I understand the solution using Mesh Analysis that was used. However, I am unsure as to why when I convert the Delta Load to a Wye load, I get the wrong answer.
    Using Zwye = (1/3)Zdelta, adding the series line impedance with the load impedance, and then finding the line current using a single phase equivalent. Am I doing something wrong?
  2. recca02
    Apr 2, 2007
    1,211
    well that wud depend on your analysis,can u post the one for y eq.?
    what do u exactly mean by single phase eq?- does it mean taking Vphase and Zphase?
  3. bobby19
    Jun 3, 2007
    13
    Essentially the Balanced Delta load becomes a Balance Wye load of 4 + j0.666. Then the line impedances will be in series with each individual load. So each impedance should be (4 + j0.666) + (1 + j2). Finally, the line currents will be the phase voltages (100 angle0, 100 angle-120, 100 angle120) divided by the series line and load impedance, 5 + j2.666.
    I cant seem to figure this out. :confused:
  4. recca02
    Apr 2, 2007
    1,211
    ok right now, cant try to solve it analytically,
    see if u can get any leads from here (assuming u got the eq resistances from the transformation figured out correctly).
    simply divide the phase voltages by impedances phase impedance values (since its balanced) this will get u phase current which is same as line current.
    does this answer not match the one by above method?
    if not post back with a little info abt your attempt , i will see if i can help (i m stuck here as i gotta submit a project report this week + some designing in m/c + something else)
