Wu meter
Discussion in 'The Projects Forum' started by 6ths3ns3, Feb 13, 2011.
  1. 6ths3ns3
    Feb 13, 2011
    i have this wu meter and i don't know what to do with it
    i want to use this in my audio amplifier ...some kind of balance or something else, but i don't know a schematic.
    the cursor of the wu meter must move in the both directions (+ and -)
    please help me :confused:
    thanks
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    The meter probably comes from an old FM radio.
    These old radios did not have a good frequency lock in (AFC) and you used the meter to see if the tuning was OK.
    Bertus
  3. 6ths3ns3
    Feb 13, 2011
    yes it is from an old radio
    but a schematic for it, please
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's not a VU meter - http://en.wikipedia.org/wiki/VU_meter
    What you have is a center zero meter. It may be a sensitive ammeter that indicates direction and magnitude of current. You might be able to check it if you have an adjustable power supply and some accurate resistors. The maximum deflection may be indicating on the order of +/- 50 microamps.
  5. 6ths3ns3
    Feb 13, 2011
    ok so in my amplifier i can't use it?
    some kind of balance schematic
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  7. wayneh
    Sep 9, 2010
    12,368
    3,224
    Well, you COULD use it, but for what? I don't have any dials on the front of my amp and I don't feel like I'm missing anything. You could perhaps - with a lot of difficulty - work out a way to have the dial correspond to the setting of your volume knob. But why?
