I am working on building a solar panel supply for a WSN node.
The logic of my design is the following:
- the Attiny uC is powered by a battery and monitors the voltage on the supercap. Whenever it decides that the supercap holds enough energy, it turns the TS5A3166 switch on and the node is powered. I have built the board and I am having some unexpected results even from the first tests.
The solar panel is rated at 6V and 100mA. The supercap is balanced with 2 * 10k resistors, values which I have calculated from the producer's recommendations.
I am currently testing with a 9V battery connected in series with a 150 ohms resistor and then fed on the board using the "SOLAR" connector.
Basically, I am seeing two problems:
1) The zener diode doesn't limit the voltage. It goes up to 4.6V without the supercap connected.
2) The LED on the "SW_OUT" line lights up whenever I put the power on, with the "IN" control pin of the TS5A3166 in a high impedance state. I have checked the connections on the TS5A3166 with a multimeter and they seem ok.
I would highly appreciate any comments regarding these questions and the design itself.
Thanks,
Alex
Thanks,
Alex
