WS2812B LED Do I Need A Resistor?
Discussion in 'General Electronics Chat' started by mathiashaugaard, Jan 20, 2016.
  1. mathiashaugaard
    Jan 20, 2016
    Hi.
    I have a small LED project, where I need to power a LED strip with 60 LED's.
    I'm going to power the LED's with an ATX PC Power Supply, where the output will be 5V - 35A.
    My thoughts were, that I just would wire the LED's directly to the Power Supply, like in this guide: https://learn.adafruit.com/digital-led-strip/wiring
    But is it safe to just power the LED strip without any resistor?
    I've seached the internet alot but I can't find the answer.
    I don't know much about electronics and therefore I need your help to determine if it's necesarry to use a resistor.
    I bought all the other necesarry things and it has just arrived, but I don't know if I abselutely need a resistor.
    Here's the datasheet for a WS2812B LED: https://www.adafruit.com/datasheets/WS2812B.pdf
    And the specific LED I use: http://www.ebay.com/itm/311509777090?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    Sorry for my bad english.
    Best regards
    Mathias.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    You don't need any resistor for this diodes.
  3. mcgyvr
    Oct 15, 2009
    4,783
    973
    LED strips like that typically already have current limiting built onto the strip..
    In this case the limiting is built into the LED itself
  4. mathiashaugaard
    Jan 20, 2016
    Ahh ok, thanks to both of you.
    The only thing I found on the internet was about single color LED's, where you need to use Ohm's law.
  5. mcgyvr
    Oct 15, 2009
    4,783
    973
    "MOST" times when you are just buying a typical LED (single/bi or RGB colors) itself you need some sort of current limiting in your circuit.. (resistor or constant current power supply)..
    Th WS2812B is not a typical LED..
